Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Rabbit (VT-90) current draw ?
Reply
Old 07-16-2015, 06:40 AM
RobinLeblond
RobinLeblond's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rabbit (VT-90) current draw ?
Hello,
I am working on a new jet and I will use my SuperReg for the Rx and servos with 2 x 2S lipo as input, output at 6v (from 8.4v), resulting in a capacity of 7.5A max current output. I was thinking about the idea of connecting the turbine (batt input) to the SuperReg output (with the receiver).
Is 6 volts is enough for turbine (pump and plug) to run properly ?
Is the turbine at startup or while running may draw more than 7.5A (or should I use the TurboReg at max 17A) ?
Do you see any problem of driving both the receivers/servos and the turbine from the same source (the SuperReg with 2 inputs)?
RobinLeblond is offline
Old 07-17-2015, 09:26 AM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Robin
6 volts are not enough, especially with kerostart
Kerostart burner draw peaks of more than 10 amps
jetmon is offline
Old 07-17-2015, 09:33 AM
RobinLeblond
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Juan, So, I will maintain my usual setup (having the turbine its own battery).
