Jet Central Turbines - Artes Jet Jet Central Turbines formerly the Artes Jet forum
Delayed Start VT-90
Reply
Old 07-20-2015, 09:59 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Delayed Start VT-90
Hi, I am having a problem which is not really a problem but a niusance.
My Rabbit takes a good minute to start. Burner goes on but it seems it have a problem hating up. During the first 40 seconds of heating up with the engine at low start speed, I see very little fuel going into the burner (and none to the combustor). Then all of a sudden fuel begins to flow to the burner and the rest is a normal spool up toe ngine idle. Engine does not ever abort start, it just takes a while.
Could it be a bad glow plug solenoid not letting enough fuel through?
Once engine starts it is business as usual.
thanks,
David
FalconWings is offline
Old 07-20-2015, 03:03 PM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hola David
It takes a while because it needs to increase temperature faster
Try to increase a couple of points to the value of "Pump Power Ig. K" in the start menu
Regards
jetmon is offline
Old 07-21-2015, 06:13 AM
FalconWings
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gracias Juan......lo tratare!
Old 07-25-2015, 10:50 AM
rcjets12
My Feedback: (21)
rcjets12's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can help with your start up to make it faster please call me at 321-412-3078
rcjets12 is offline
Old 09-19-2015, 03:56 PM
tshah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have issu with my rabbit, it try to start ok but as soon it comes up to speed and it says switching over that's when it just cuts the fuel and starter keep turning the engines till I kill. No massages.
tshah is offline
Old 09-20-2015, 12:00 PM
rcjets12
My Feedback: (21)
rcjets12's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Tshah
i will need more info but you can start by increasing the PW Ignition K by 2 points at a time be careful as this will increase the fuel amount. I will be back in the the States on Tuesday and you can call me then.
rcjets12 is offline
Old 10-11-2015, 04:28 PM
FalconWings
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok I tried increasing pump power ign k from 36 incrementally to 48. It didnt help much, but I did notice a lot of flames in the back.
Anything else I should try? Once is starts it runs fine.
Old 10-13-2015, 07:57 AM
FalconWings
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bump.....otherwise the drama on the the thread above will pervail.
Old 10-14-2015, 05:16 AM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Falcon
Please call jose to instruc you to unlook the ECU, so we can encrease the Fuel Ramp setting
In the mid time return your pump power to original setting to get rid of the flames
Regards
jetmon is offline
Old 10-14-2015, 06:53 AM
FalconWings
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gracias Juan, will do.
Old 10-14-2015, 07:13 AM
E.N.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hola David, Hector here. You said VT90, that's a Merlin. Yours is a Rabbit.
Hector
E.N.T. is offline
Old 10-14-2015, 08:58 AM
jetmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hector
Hola Hector
Nop. VT90 and VT100 are Rabbits, the merlin VT80 came out a couple of years later
Regards
jetmon is offline
Old 10-14-2015, 12:43 PM
E.N.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, Juan, you were right. Sorry.
I have the VT-80. Merlin.
Hector
E.N.T. is offline
