Super slow throttle respound ,super eagle
My Feedback: (176)
Hi to all maybe you know what could be the reason for slow throttle respound and not reaching the max rpm in my super eagle ,the fuel line is not restricted new fuel lines and filter the turbine have only 125 min run time ,I might replace the fuel solenoid to new one later.thanks for all ideas and respound .
My Feedback: (176)
Wok so after replacing new filter and fuel solenoid no improvment the respound it's super slow till about 90.000 rpm and then got much faster like normal the fast respound stays between 100.000-127.000 and when go back to idle again the turbine have problem to clime back to 100.000 rpm maybe about 30-35 secound .
My Feedback: (21)
FL
It will depend on the type of ECU that you have,
You will need instructions to unlock it so please contact Jose Melendez at 321 412 3078
Regards
Regards
