Lynx
My Feedback: (336)
MO
Lynx
Getting ready to buy a lynx
what is the spool up time from idle to full?
Also does it come with a FOD screen like the other brands or do I need to buy separately.
If so what is the part number?
thanks
thanks
Hi,
In today's turbines, pretty much all the manufacturers have kinda the same throttle response.
The spool uptime is a couple of seconds depending on the setup 4-8 sec.
You can watch some of the videos of Jase Dussia or Pablo Fernandez running this turbine in the Havoc GTS, throttle response is amazing.
You can find more info here https://www.aeropanda.com/products/j...-130-se-series
It comes with everything that you will need to install and use the turbine. (Jetcentral include everything even the tubing)
If you need more info you can contact me directly at AeroPanda.
Manny
JetCentral USA
Manny
JetCentral USA
