NOISE
NOISE
From those of you that have experence with TURBOPROPS Jetcat or Wren ...How much noise do they make....COMPERED to a recip / glow / gass motor of similar HP ....8 to 10 hp .. thangx in advance TROU
My Feedback: (10)
FL
RE: NOISE
Hello:
www.jet-central.com will take you to Jet Central Micro Turbines Web site. As for noise, it is in most cases controlled by propellor selection.
OUr jf 50 TP has been flying for more than a year mostly in Comp-ARF Tucano's (4 known) an in my case, the Great Planes CAP 580 Giant. We are using a Beihl 24 X 12 three blade with a prop RPM of almost 6,000. Noise is less than a normally operated turbine and far less than a gas banger. Observers repeatedly report our turbo prop sounds much like the 1 to 1's you fly in or watch.
I can supply references of NON TEAM pilots who are operating our system for further information should you need it. Our complete system with Lifetime Warranty is $4,995.00 plus $30.00 shipping within the USA, delivered to your door.
Best regards,
Eric Clapp
Best regards,
Eric Clapp
