5% oil for Falcon?
5% oil for Falcon?
I believe I did read that between 2.5 and 5% oil is acceptable for the falcon but I just want to make sure.
What is considered to be the ideal oil mix for the Falcon? Jet Central's in general?
Pete
Pete
FL
RE: 5% oil for Falcon?
Pete:
I know you received a manual with the turbine you purchased. Manual clearly states 2.5% oil to every 5 gallons. You may use 5% however, it is not necessary.
Regards,
Eric Clapp
Regards,
Eric Clapp
