Rabbit KS Igniter voltage..
Got a new Rabbit KS that is giving me some startup grief and the not so wanted "pump limit reached" error message when I finally get a start. Working with Eric to sort it out, but in the meantime, what is the typical igniter voltage set at?
Using a 3 cell LiFe pack, and have switched it over to 2 cell LiPo during my fault finding sessions (no change) and I see the igniter voltage at 5.4v. Is this typical? Dan |
RE: Rabbit KS Igniter voltage..
Hello Sparhawk
The newest igniters are rated for 5-6v so 5.4 is normal Previous igniters were 6-7v and normal setting was 6.5v Regards |
Thanks Juan.
My Rabbit is heading to Kerry to have a look it. Ithink Ihave a couple issues, and one is a pump that is maybe too tight and needs a breakin, so that the ECU doesn't have to work so hard to pump fuel. The other looks like the setting for burner fuel, and it is just low enough that it is 50/50 on whether it will jump toSwitchover mode. Kerry may need to unlock it and turn up the flow rate a little, as there is just not enough to keep the burner lit. Love the Rabbit and can't wait to have it back. Dan |
ORIGINAL: Sparhawk Thanks Juan. My Rabbit is heading to Kerry to have a look it. I think I have a couple issues, and one is a pump that is maybe too tight and needs a breakin, so that the ECU doesn't have to work so hard to pump fuel. The other looks like the setting for burner fuel, and it is just low enough that it is 50/50 on whether it will jump to Switchover mode. Kerry may need to unlock it and turn up the flow rate a little, as there is just not enough to keep the burner lit. Love the Rabbit and can't wait to have it back. Dan |
