approved oils
Is there a list of approved oils that can be used in a JC turbine, can kingtech oil be used?
Karl:
Jet Central recommends using synthetic oil such as Amsoil Dominator at 2.5% or 1/2 quart to 5 gallons. Other acceptable oils are: Mobil DTE lite - Must use one (1) quart to 5 gallons BP2380 - use 1/2 quart to 5 gallons Aero Shell 500 - use 1/2 quart to 5 gallons (not our favorite but acceptable) Motol synthetic - 2.5% to 5 gallons Any turbine oil or synthetic oil with a JASO FC rating. Regards, Eric |
Thanks Eric, can I use kingtech oil in a JC turbine.
Karl:
JASO FC rated oils are OK. While possibly amusing, I was given a quart of Jet Cat oil which I used with no issues. Regards, Eric |
Thanks Eric for your response.
Hello Karl
We haven't had the chance to test the kingtech or JetCat oils in our turbines, so at the moment, they are not approved |
Thanks Juan and Eric that is the definitive answer I needed .
Originally Posted by BluFox
(Post 11983140)
Karl:
Jet Central recommends using synthetic oil such as Amsoil Dominator at 2.5% or 1/2 quart to 5 gallons. Other acceptable oils are: Mobil DTE lite - Must use one (1) quart to 5 gallons BP2380 - use 1/2 quart to 5 gallons Aero Shell 500 - use 1/2 quart to 5 gallons (not our favorite but acceptable) Motol synthetic - 2.5% to 5 gallons Any turbine oil or synthetic oil with a JASO FC rating. Regards, Eric any harm or benefits to mixing the BP2380 at 5% instead of using half the quart to get 2.5% in a 5 gallon container? also, is this oil hygroscopic? In other words, if you only use half a quart at a time, what's a safe way to store it so it's still usable in a month? |
Originally Posted by luckymacy
(Post 12072258)
also, is this oil hygroscopic? In other words, if you only use half a quart at a time, what's a safe way to store it so it's still usable in a month? for or all the years that I have been using Jet Central I have always used a 5% mix. I always have used 32 ounces per 5 gallons of fuel. You will not harm the turbine by using 5%. The only approved oil that will give you issues is if you use the Amsoil because it could get you bearings gummed up. For Amsoil don't use more than 2% because of this reason. Especially on the smaller engines like the bee and the rabbit. |
I've been wondering the same thing: what the heck am I going to do with leftover 1/2 of a quart of BP2380? Will it "keep", or will it get contaminated if I don't use the whole quart once it's opened?
So, using the whole quart in 5 gallons of kero - 5% mix - is ok in a Rabbit? |
5% is ok
Great, thanks. I'd hate to see half a quart of oil go to waste, so good to know that using the whole quart of oil in 5 gallons of kero is ok.
Originally Posted by VF84sluggo
(Post 12080460)
That's the other solution...just make up two 5-gal jugs.
But, frankly, I just don't feel like measuring out 16 oz of carcinogenic turbine oil in some type of container; then have to clean that container so there's no oil residue; then package it up somehow so it doesn't collect dust/dirt. I'd just rather dump a whole quart in the jug (while wearing disposable gloves) and add 5 gallons of kero. Yeah, I thought the glove thing was overkill, too...until I noticed that the mechanics at my airline all wear them when they handle BP2380 or Mobile Jet Oil II (the two types I've seen on the rack). So, to each his own. But for me, based on Juan's post (#11), I'll just add a whole quart to the 5-gal jug and be done with it...like I've done when I had jets with those purple turbines. |
(Post 12080581)
But, frankly, I just don't feel like measuring out 16 oz of carcinogenic turbine oil in some type of container; then have to clean that container so there's no oil residue; then package it up somehow so it doesn't collect dust/dirt. I'd just rather dump a whole quart in the jug (while wearing disposable gloves) and add 5 gallons of kero. Yeah, I thought the glove thing was overkill, too...until I noticed that the mechanics at my airline all wear them when they handle BP2380 or Mobile Jet Oil II (the two types I've seen on the rack). So, to each his own. But for me, based on Juan's post (#11), I'll just add a whole quart to the 5-gal jug and be done with it...like I've done when I had jets with those purple turbines. I agree with you I have always used 5% all the years I have been flying turbines with no issues. One quart per 5 gallons. |
Has there been any update regarding the use of Kingtech oil in Jet Central Turbines? If someone already owns a Kingtech turbine and already using diesel fuel with 5% Kingtech oil will they have to have a separate fuel supply for the Jet Central turbine?
I have a JC Cheetah and a Kingtech K210. I run gas station Diesel with 5% kingtech for both the turbines. No issues.
Originally Posted by GULDUKAT
(Post 12371124)
Yes.
Last question. About how many hours on the Cheetah since you started using the Kingtech oil? I wish Jet Central would update there statement on using Kingtech oil since it has been a couple of years since the question was asked before.
Not sure on the hours.
5% Kingtech with kerosene in winter about 20 flights 5% Kingtech with diesel in spring and summer at least 30 to 40 flights. We'll see how diesel performs this Winter. So far the performance with diesel is much better than with kerosene. |
I have to apologize to Jet Central because Juan Ramon Ruiz from Jet Central sent me an email on September 18, 2017. I just happened to check my spam folder looking for something else and saw his response. He stated that Jet Central still has not tested Kingtech oil with the Jet Central Turbines but does acknowledge that a lot of the clients are successfully using it and if you use it follow the percentage Kingtech recommends. Thanks guys. I hope to purchase a Rabbit in the near future for a project and I am also looking at a 70/80 size turbine for another project but the Bee is a bit much $$$ compared to other brands. I just wanted to find a common type of oil for different brand turbines.
Originally Posted by pcskyhi
(Post 12371277)
, . I just wanted to find a common type of oil for different brand turbines.
John |
I am also wondering about the Kingtech Oil in Jet Central engines.. ( Cheetah and Rhino's ) ... I sure would like to get Juan's blessing on it. Had a stray Kingtech 210 show up on the doorstep in and looks like were going to feed it.... :) Same situation as stated, don't wan't to have to haul 2 fuel supply's. Truth be known, I think Kingtech oil is nothing more than DTE Light with a few ounces of snake oil with a new label and a big price...
Dan |
Originally Posted by rcjetsaok
(Post 12372870)
Dan |
