JetCentral SE Powerpack Receiver / Throttle Input Voltage
I just wanted to confirm the max voltage for the receiver battery on the SE powerpack on a JetCentral Bee 80 SE. The manual does not specify a voltage range for the receiver / throttle input. I am running a 2S lipo for the receiver and servos at 8.4V.
Will this be ok to plug in directly to the ECU or will it need to go through a regulator? |
Hello 330rule
You can use it directly, no regulator needed Regards |
Great thanks! |
