Big Flame on Start up of My 120SE
RE: Big Flame on Start up of My 120SE
just pull the Kero tube off the turbine, stick it into a cup and use the GSU to set it. you want it to start reliable at the lowest voltage.
Thanks again KC.
I don't know why I am having this trouble anyways. This engine was moved from my Kingcat where it had no problems and now moved to my Elan where the problems have started. I moved the engine and the ECU only and not the pump. The pump I am using is from a brand new P-200sx. The engine from the Kingcat is not that old either. I do believe that there is no difference in pumps from Jetcat to Jetcat,it 's just the age of the pump correct. The pump gets told by the ECU what the voltage to run at. Like I say this engine never had a problem in the Kingcat. Any comments.
Thanks for help
Alan
Thanks for help
Alan
Hey KC
Do I feel stupid. I found the problem in my big hurray in swapping engines I placed my kero start solenoid on the input above the propane input, and so it was getting a steady stream of fuel from the igniter line and the fuel line. Hence the reason for the big orange fire ball. I put my pump voltages back where they were. I think things should go a bit better next time out. Learned a big lesson here, check twice or three times before hooking up.
Thanks for the help anyways.
Alan
Alan
