Battery boost using Led I/O board
Hi,
I am using the led IO board with charge plug with my F16 with P200SX.
I would like to use a boost external lipo pack (identical) just for startups.
Can I use it directly through the charge port in the board?
Ziv
Ziv
RE: Battery boost using Led I/O board
Yes, been doing it every since that board came out, they don't even have to be of the same capacity, but the ECU/Starter will draw power from the battery that has the lowest resistance, this will generally be one of higher capacity.
Mike
Mike
