Titan Kero Start and GSU
I have a Jet Cat Titan with an upgraded ECU to V6.
I have connected a Kero Plug. Pressing Min/Max and Ignition at the same time switching on the receiver and holding the GSU buttons does not bring up the Kero start.
Does anyone have any ideas why it is not changing to kero.
Thank you
Thank you
FL
RE: Titan Kero Start and GSU
There are two versions of the V6.0 program that I am aware of....one for ECU V6.0F, and one for V6.0E and older.
You have been using the procedure for V6.0F.
Try this for V6.0E or older:
1. Switch OFF RC receiver.
2. Connect the GSU to the I/O board.
3. Simultainiously press and hold the GSU "Ignition" and "+" buttons.
4. Switch the receiver "ON" and hold for a few seconds.
After a few seconds the GSU display should read: "KEROSENE (6V)
Start activated"
5. Release all buttons.
Hope this helps.
Start activated"
Hope this helps.
