Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Reload this Page >
P20SE dual "Valve Plug Here" on pump
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 07-23-2011, 01:57 AM
Couch Potato
Couch Potato's Avatar
Default P20SE dual "Valve Plug Here" on pump
Hi,
Why are there two duplicate connections for the propane/fuel solenoid block on opposite sides of the pump ?
Does it matter which one I use (for single turbine ops) ?
Thanks.
Old 07-23-2011, 03:06 AM
BaldEagel
BaldEagel's Avatar
Default RE: P20SE dual
Quote in the manual: "The connector for the valve block is double on both sides under the pump cover. Plug the valve block cable to any connector"
Mike
Old 07-23-2011, 03:15 AM
Couch Potato
Thanks Mike.
Should have realised that the manual that came with it was the generic P60-P200 and I needed to go find the P20 one online.
http://www.jetcat.de/downloads/p20se...ition_-eng.pdf
Old 07-23-2011, 04:23 AM
BaldEagel
BaldEagel's Avatar
Mine came from Al's Hobbies and had the specific P20 manual in the box with it.
Mike
