P-160 Titan Fuel Leak
My Feedback: (20)
Need help to find fuel leak.
There is fuel dripping from bottom of my P-160 Titan after each shutdown. It seems to be dripping from where the purple cowl meets the engine case. Any ideas on what to check. Turbine runs great, starts great with kero starts, but drips fuel on each shutdown. I can not see any leaks during running. Any ideas on what to check and how?
Gary Jones
Gary Jones
RE: P-160 Titan Fuel Leak
Could be a few things, cut in fuel pipe, fuel pipe not pushed in fully to festo fitting or festo to fuel ring join which may be a push or screw on and just needs tightening up. Take the cover off and check.
My Feedback: (10)
Hi Gary,
As Xairflyer pointed out it could be a couple of things. There are push on (festo) connections under the cowl, you can check to make sure they are secure. Note, there is very little excess line to trim them if you need to so be careful. Also, make sure you do not inadvertently tear the inside of the line if you remove the line from the brass nipple going into the fuel ring.
For the fuel ring itself, there in a large o-ring that goes under it, I would not go farther than to make sure the screws are tight that hold it on. A small amount of leakage is not a big deal so it is up to you to decide if this is critical.
My Feedback: (20)
Thanks Xairflyer and Mr Matt,
I will be a week or two before I can get back and check under the cowl. I will let you know what I find then. I really appreciate the help.
Gary
Gary
