160 booster cant start
hi all, i need some help please. just bought a 160 booster with 1 hour 12 min on the clock.went to start it today and the first start failed ,it said to1f on the ecu, so tried again,it started then when i moved the throttle to half it cut out and said max t on the ecu,now every time i try and start it its starting ok but when its just about to settle on idel it cuts out and says max t on the ecu all the time.need some help cos its doing my head in now, hope you can help steve,
RE: 160 booster cant start
oh i think you didnt learn the ecu with your transmitter
you have to go to different steps
before you can run it
you can do idle , half trotle , and full throttle
learn the ecu , transmitter agian
maybe this helps
Regards,
Martin.
maybe this helps
Regards,
Martin.
