V10 ECU - 2S Lipo (7.4V nom) on Throttle/Aux inputs?
CA
Hi,
Did some searching in the manual and on the forums but couldn't find a definitive answer.
Can I run the V10 ECU in a high voltage Rx/servo setup, i.e. running 7.4V nominal from a 2S Lipo into the Throttle/Aux inputs on the ECU? I would expect I can but want to make sure.
Specifically note that my question is *not* about the ECU power itself (running the 3S LiFePo as supplied by Jetcat there).
Hans.
Hans.
