Flashing green light
When I turn the jet on my ecu green light starts flashing as if its in slow down mode, trim is full low and switch is off. Nothing I do changes this im guessing I have an issue?
Its showing 105 on the temp but the engines is cold and hasnt ran since I flew it last at MS jets. It flashes 105 then -E- back and forth so maybe my temp prob is dorked?
What engine model? if it has an external temp sensor like P80 or p120..etc then most likely you have damaged the small silk that soldered in the temp probe connector board, open the front purple cover and inspect the sensor closely, if it was cut then carefully try to solder it again and do temp calibration again from the GSU, i had this issue in two of my engines and i have fixed them same way.
Marwan
Marwan
yes it has the external probe, I found the problem. The screw that holds the black plastic cover on which also holds the temp probe on came out and the temp probe was not connected. Thanks for the help
