JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
140 rxi
Old 05-19-2016, 08:02 AM
AKB
Default 140 rxi
What procedure do you use for priming. I was a little hesistate at first for fear of a wet start. But as usual minius the exterior pump, I very quickly let the buttons go on the GSU when the fuel got to the fuel intlet festo. No wet start so I guessed right I think? So use to priming with the line off and letting it go into to a small cup.
Alan
Old 05-20-2016, 04:00 AM
Jetkopter
Alan, that's all you need to do ! I use the same procedure.
Old 05-20-2016, 08:42 AM
AKB
Thanks Jetkopter, just a little different procedure that I have used in my past Jetcats.
Alan
Old 01-24-2017, 10:27 AM
helifox
helifox's Avatar
Alan
Hi Alan, you a bit wrong, because P-140rxi has internal fuel pump.
I also worried how to do a priming on RXI series with internal pum (my P-140rxi on way).... I have no idea like to stop priming fuel about 1mm before gets in Festo inlet.
Old 01-25-2017, 11:50 AM
AKB
Hi
I ended up getting primed. You just have to be quick to disengage the the switch so you don't flood the engine.
Good luck
An
Old 01-26-2017, 02:05 AM
helifox
helifox's Avatar
Thanks An
