JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
P120 "over-rpm"
Old 02-06-2017, 05:35 AM
dgrdan93
Default P120 "over-rpm"
I'm new to turbines. My P120 that I recently picked up seems to start just fine but during the warm up process or perhaps just after it the turbine then revs up without any command to do so. Maximum RPM is set to 70,000 and has caused the engine to shut off on both occasions that I've started it. The manual states that during warm up the turbine will only reach approximately 55,000 RPM. No transmitter has yet been used to start it, only the GSU. Is this normal? Shall I just increase the Maximum RPM limit?
Dan
Old 02-06-2017, 08:21 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Hello. Which menu says "70000 rpm" max?
Old 02-07-2017, 04:26 AM
dgrdan93
It says 70000 rpm for maximum rpm within the limits menu. "Last MaxRPM" within the info menu reads just over 70000 rpm from what I recall. I believe the ecu is version 6.1.
Old 02-07-2017, 04:34 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Well a P-120 max RPM should be maybe 123K, so I would start there.
