P 100 rx V10 ECU
P 100 rx V10 ECU
Hi
I have a problem with my P 100 when I plug in my battery into the ecu the starter motor kicks in and keeps running the only way to stop it is unplug it,up to that it worked perfect ecu gets quite hot as well anyone any idea .
thanks
Andy
thanks
Andy
Then try a reset (Hold select menu button down, switch on rx and hold button ignoring learn RC and temp calibrate)
If that does not cure it ECU needs to go back
