P20 Pump problem
P20 Pump problem
I have just replaced my fuel pump on my P20, ver10 ECU, as the old one wouldn't pump fuel, even though it would turn. When I run the new pump in the test menu, it pumps fuel perfectly, but when I go to start, a message "no pump" comes up! I have tried resetting ECU to factory, learning RC, but no change. Would anybody have any ideas of what might be going on?
What software version do you have on the ECU? If its an older type (10.2-10.3) and the pump is the latest software the ECU won't match the pump (JetCat call it seeing the pump to link) on boot up. It definitely says Fuel Pump during the boot up phase-the bus pumps can be set to smoke pump. Should be B2 pump.
Is it 10.0D or? Could be 10.0, 10.1, 10.2, 10.3 or latest 10.4 and a letter.
I should say what pump is attached and a V number for the pump too.
You will have to talk to Peter and find out if he can flash the ECU's in Aus
Dave
Dave
Dave, all good, apparently the ECU needs to be flashed, but for others out there, if you have a digital Jetcat pump and need to replace it ,
there is a strong chance that you will need to send your ECU back to a service centre to make it compatible with the pump. Peter from Interairco can do the job here in Australia.
