Unit of measure for "Last Fuel Count"
My Feedback: (10)
Yes, ml
You can change the initial amount with a setting, unfortunately you cannot change it withough the GSU when you pull the taxi tank, that is annoying.
This also reads out when you are testing the pump, so I usually run a liter or 2 through the system and see how accurate it is. My last time it was about 15% off,
