JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
P-80 ecu battery change
Reply
Old 07-18-2018, 11:15 AM
shepp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default P-80 ecu battery change
Ok guys
I have an older v-6 ecu on a p-80 se
the ECU has been changed to A123
but I forget how to change battery type to a 3 cell li-fe
i have done this before but forget how. The only options currently listed on the ecu is 2cell li-po or 6 cell nicad.
Any help?
Shepp
shepp is offline
Old 07-18-2018, 03:24 PM
sam@ata
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just started into the black ops of turbines with a P80 and a V2 Turbinator. Be nice to know also so i can add it to the notes in my manual. I assume that the LiFe battery upgrade may be in a newer ECU version as i have been through my menu options getting use to the structure and not seen but those two options.
sam@ata is offline
Old 07-22-2018, 03:37 AM
aehaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only reason to select a particular type of battery is to be able to have a proper low voltage auto cutoff. Either of those settings will work with the 3s LiFe. You will not get the proper cutoff but who cares if you always properly charge your batteries.
aehaas
aehaas is online now
