JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
P70 battery low error
Old 08-19-2018, 02:45 PM
rusty55125
Default P70 battery low error
I have a Jetcat P70 and went to start it for the first time this year and had an issue. The GSU shows it to be a low battery. I checked that battery and it is full (7.2 Lipoly at 8.4v). Checked the battery voltage at the end of the lead and it's at the proper voltage. I connected up to another controller from my P160 and it shows the proper voltage. Do I need to send it in to get checked out, or is there something that I can do, like reset it?
The GSU shows zero voltage. and "OC:battrylo"
Scott
Old 08-21-2018, 12:48 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Hi Scott,
When you said it worked when you hooked up another controller, do you mean a different ECU?
Old 08-21-2018, 04:12 PM
rusty55125
What I meant was that when I hooked up another ECU, from my P160, the battery was able to supply voltage. The ECU from the P70 is still not working and giving a "OC:Battrylo" error.
Scott
Old 08-22-2018, 10:06 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Yes I would say the ECU is bad, but I would try another battery with the P-70 ECU just in case.
