P300rx
My Feedback: (22)
P300rx
I just received my P300RX from service. Software/firmware's were updated.
The engine starts fine. Acceleration and deceleration ok.
But, if I bring the power up when the engine is decelerating in the lower RPM range, It starts spitting out blue flames and the EGT rises. I guess the engine is stalling at that point.
Acceleration curve too steep?
Any advice?
Any advice?
My Feedback: (22)
I guess I found the throttle respond.
“FullThrResponse” was set to fast. I changed it to normal.
Thise are the only 2 options I can choose from.
”IdleThrResponse” was set to normal. I had to change that to slow and that actually solved the problem.
i have to say, that really reduced the spool-up time a lot! Maybe to much.
You think increasing the distance from cone/pipe would help also?
Thanks Dave.
Thanks Dave.
