JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
160sx
Old 10-17-2019, 07:28 AM
snir2001
snir2001's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 160sx
Hi,
I bought a used 160sx with less than 11 hours.
The turbine spin freely and works great.
One issue is that the turbine dripping fuel during the startup phase from the back of it, between the can to the exhaust cone.
It does not look normal to me.
Any ideas?
snir2001 is offline
Old 10-17-2019, 07:39 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A bit more info will be nice, are you seen flames when the engine is in the start up sequence? If you see flames it may be an indication that it is getting more Kero than needed during start up. Have you check the fuel drip for Uaccelr1.
CARS II is offline
Old 10-17-2019, 08:57 AM
snir2001
snir2001's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Carlos, I will check it.
On the first start, the turbine shows some flames, but all other starts went fine.
I will dial the pump down a bit, I hope it will help.
snir2001 is offline
Old 10-17-2019, 06:22 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some guys don't bother to adjust the pump after they are broken in ( around 2-3 hours of use) they come set from factory to 2.0 v, you may find that it needs to be readjusted from something like 2.75 v to 1.75 v or so, depends on the drip, also make sure the filter
let us know of your findings.
Tks.
CARS II is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
