JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
P300 RX poping at Idle
Old 10-30-2019, 02:17 PM
j.c.a.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default P300 RX poping at Idle
Hi just installed a P-300RX which came back from service, at Start up I get plenty of flames and at Idle there is quite a bit of poping , any suggestions would be greatly appreciated.
I am using diesel,
Thanks in Advance
J.C. Alvarez
j.c.a. is offline
Old 10-30-2019, 02:37 PM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you do a full power run? Its gone back into an airframe it was in before, where its didn't 'pop' in the tail pipe? It was always run on Diesel?
Dave Wilshere is online now
Old 10-30-2019, 02:44 PM
j.c.a.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave, thanks for nthe quick reply,
1. Yes I did a full power run up and no problems it accelerates just fine and reaches 104000 rpms
2. no it is not in the same airframe gap at pipe is 1 inch approx. 25 mm
3. no previously I ran on Kerosene
thanks
J.C.
j.c.a. is offline
Old 10-30-2019, 10:05 PM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK. Gap is too small. What dia pipe? If it’s around 105mm the gap should be 40-45mm
Dave
Old 10-31-2019, 08:01 AM
j.c.a.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Dave Wilshere View Post
OK. Gap is too small. What dia pipe? If its around 105mm the gap should be 40-45mm
Dave
Hi Dave, the Diameter on the pipe is 100mm, Today I will try to move turbine forward and also try kerosene before I move it.
I have heard that some Jet Cat Turbines do no run good on diesel is correct ?
Once again thank you,
J.C.
j.c.a. is offline
Old 10-31-2019, 11:36 AM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I’ve never used Diesel, I thought only the smaller turbines were fussy on fuel. Gap will add a bunch of power and should help on the air popping
Old 10-31-2019, 04:07 PM
j.c.a.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave, tried kerosene and poping improved 90 % , I then moved the turbine as you suggested poping is still the same with 90 % improvement, I also tried the diesel again and poping returned.
Going to run it on kerosene .
Once again thanks for all your help
J.C. Alvarez
j.c.a. is offline
Old 10-31-2019, 10:13 PM
Springbok Flyer
Springbok Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get a new pump.
Springbok Flyer is offline
Old 11-01-2019, 01:43 PM
j.c.a.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Springbok Flyer View Post
Get a new pump.
Hi , Why do you suggest getting a new pump? reason I ask is a new pump here in the US is $499. and if that does not fix problem its not returnable I don't mind spending the $499 just want to be sure this solves the problem.
Thanks for the input
J.C.
j.c.a. is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
