JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
P100RX -E- code
Old 01-18-2022, 05:21 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Default P100RX -E- code
Was doing a Bandit ARF maiden, and the P100RX flamed out during a half cuban eight (likely at the top). Note that engine is not new, just a few hours of use
Upon deadstick, ECU was reading -E- code (for bad thermocouple).
My question is, flat out replace the thermocouple or troubleshoot elsewhere? Also, kind of thought a bad TC would not kill the engine in flight, correct?
Otherwise, nice engine. Lot's of push.
David
Old 01-18-2022, 09:23 AM
Dave Wilshere
David
It can be the cable, definitely plugged into the turbine still? x E x flashing?
Has the cable got small fine wires running with the larger cables? If so change the lead to the new type
Dave
Old 01-19-2022, 05:23 AM
FalconWings
My Feedback: (57)
I will check tonight and report back Dave. Thanks
Old 01-20-2022, 02:49 PM
FalconWings
My Feedback: (57)
I can't tell which cable I have Dave. GSU display now is blank, could be ECU battery. Waiting on an MPX adapter so I can verify charge.
Old 01-20-2022, 03:20 PM
Dave Wilshere
That is the old turbine cable. I would definitely order the new type for turbine to ECU and ECU-pump
Dave
FalconWings (01-20-2022)
Old 01-21-2022, 03:12 PM
FalconWings
My Feedback: (57)
Dave... It was the cable on the engine end. It is stiff and the 90 degree bend has damaged the wires....so power is intermittent. I was lucky it did not die sooner in the air.
Ordering the new cable as we speak!
Thanks for your help
David R
Old 01-21-2022, 11:58 PM
Dave Wilshere
David
OK, the new cable has a 90 degree connector moulding.
Dave
