Smoker Setup
Smoker Setup
The manual shows a smoke system using pressure. My question is does the pressure come from the propane tank (open the propane valve and the smoke valve) or is pressure coming from the case?
ON, CANADA
RE: Smoker Setup
From the diagram the propane tank is clearly pressurising the smoke tank.
I'm not saying that it IS so, but the diagram is definately 100% saying that.
My Feedback: (10)
RE: Smoker Setup
ORIGINAL: causeitflies-RCU
I hope that helps.
Regards,
RE: Smoker Setup
Thanks Matt, that's what I was hoping.
Next questions are whether the valve has to be plugged into the ECU or can the Rx power it? The smoke valve is just a fuel/propane valve right? Can it be proportional?
I know guys have plumbed it differently to use the propane tank for pressure. Since I'm using Kero Start I can get some use out of that useless propane line but I want enough pressure for good smoke.
My Feedback: (10)
RE: Smoker Setup
Yes you need to plug the valve directly into the ECU. The ECU controls the valve, and you use the ECU aux channel to turn smoke on and off. The ECU can also control the smoke itself, to send coded messages (almost like morse code) if you have a battery problem, failsafe or something like that.
And yes the valve is just a shutoff valve, on or off.
For a kerosene start option, you would just run the now unused propane fitting from the front of the cowl to the smoke tank plumbing. Then the smoke valve operates the same as it would in the case of a propane/butane starting turbine. I have not used one myself but I know others that have and were please with the performance. It certainly is simple and worth trying before going to an external pump, as the only delta cost is a shutoff valve that most people have a spare for in any case.
Hope that helps somewhat,
My Feedback: (25)
PA
RE: Smoker Setup
Matt,
how much pressure is available at the propane port?
also the diagram looks like it pushes propane into the smoke tank during startup??
I too have kero start and would really love to use the pressure tap from the turbine if thats really whats going on.
thanks,
chuck
thanks,
chuck
My Feedback: (10)
RE: Smoker Setup
ORIGINAL: chuckels
Matt,
thanks,
chuck
Matt,
thanks,
chuck
I do not think very much starting gas would go into the tank, as the flow rates are very very small.
Hope that helps,
