P-120 starter
NY
P-120 starter
I have a P-120 and having trouble starting. The plunger that holds the O ring does not seem to be comming out far enough, and when it does, it stays out and stays engaged with with the turbine center shaft. Is there any way to lubricate the plunger. I have tried cleaning it with alcahol, but it does not help.
My Feedback: (10)
RE: P-120 starter
ORIGINAL: Boating Bob
Hi Bob,
There is a home method to lube that cone that has about a 20% chance of working, otherwise the turbine has to go in anyway. If you are game I will tell you how to do it, just PM me and I can walk you through it!
Sorry for the inconvenience,
