A123 Battery for JetCat ECU
My Feedback: (10)
RE: A123 Battery for JetCat ECU
ORIGINAL: Airforce7
Matt,
I just bought an A123 9.9V 2300 mAH pack for my P-120 (non-kerostart) ECU. How many flights do you think I'll average and which GSU menu setting do I need to change?
Ken
Matt,
Ken
Hi Ken,
Sorry for the delay, busy at work.
You should get 4-5, but I don't know much about a123 cells. I would not push it until I charaterized the pack (ie run a couple of flights and then discharge to see what you have left, at a pretty high rate). Checking what goes INTO the pack can be very misleading, but a good discharge cycle gives a lot of information.
The setting is for 8 cell nicad but unless you are using the low battery warning features of the ECU you can ignore it.
Regards,
Matt
My Feedback: (31)
Matt,
I received my A123 ECU battery today. I went to the Limits menu in the GSU for my P-80 version 5.10E ECU and can only select three options. They are NiCad 6 Cell 7.2V, LiPo 2 Cell 7.4V or Lipo 3 Cell 11.1V. Where's the 8 Cell setting?
For now, I'll leave it at NiCad 6 Cell with the low battery warning disabled and monitor the voltage on the run screen.
See picture below of the new A123 battery side-by-side with the 6 Cell NiCad from JetCat.
Ken
Ken
My Feedback: (31)
Matt,
Just out of curiosity today, I tried to set the cell count from 6 to 8 in V5.1E using the same method Bob described to me for V6.0A and I was able to do it. If I'm able to do it, then I'd like to know if there's any other menu that needs attention.
Ken
Ken
6 to 8 NiCd ECU
I would appreciate if you could send me details for this on PM ..
Thank you
Kins Regards
