Moki replacement carb
Any chance that you will be making a carb for the Moki/Mark motors? It's next to impossible to find them and I much prefer the performance of the Jett to start with.
Thanks, Mike |
RE: Moki replacement carb
I believe Dub can get the Jett carbs to fit. Check on the barrel dimension and email him directly.
Moki information says the OD on the Moki carb to the crank is 20mm.
Yes,
Dub custom fits the carb bodies for these engines. We usually have the engines sent to Jett Engineering carb is installed and set up. |
