JR9303 slow roll button?
Hey all, maybe someone can help me. I sure cannot figure it out. I would like to use the snap/timer button for a slow roll button. I know you can program zero rudder and elevators, with a little aileron, but if you are pushing the button you have lock out the rudder and elevator stick control. I friend told me that you could assign the button to AUX4 and mix AUX4 to the ailerons, I cannot seem to make it work. I sure some one has figured it out. Thanks for any help. T green
My Feedback: (31)
NC
RE: JR9303 slow roll button?
so u are only wanting the button to let the ailerons rolls at about 5-10 degrees? From here you are ready to give it the imputs of rudder and elevator is this correct thinking on my part?
In DeviceSEL, set the input for AUX4 to BUTN and INH the output. In a linear program mix, mix AUX4 => AILE. Leave the upper value of Pos0 as 0% and set the lower value of Pos0 to some value of your choice. Leave the Offset at 0. This is a quick set up without frills.
Allan
Allen. I am going out to try it, thanks, I just hit a brain freeze. let you know how it turns out. got to clean the garge first, under order from wife. thanks for the help
T green www.craptech.net
Allen, It seems to work, but when I change the value of the liner mix it changes the value of my ailerons. So if I only have a little deflection on the ailerons for a slow roll( pushing the button), then I only have a small movement with the stick, I will work on it later tonight. Got to get back to the cleaning. Thanks tgreen
ALLEN GOT IT, just like to you told me. thanks again
KRAYRC- I just wanted the button to move the ailerons for slow rolls and till have control of the sticks for rudder and elevator. back in the old days I would just solder a 5k pot to the aileron pot replace the trainer swtch with a button, and there you have it.
thanks guy
T green
www.craptech.net
thanks guy
T green
www.craptech.net
