JR 9xII problem setting model
I have a JR 9xII transmitter. The problem is that all channels do not show up when I try to program a new model. Channel 1 shows up 25 times out of 30 options. and whichever other channel or model I set last, channel 1 settings take me right there when I try to program a new model (like it was a short cut). Channel 1 shows up as 1 modulation, alongwith a few other models I have programmed. Can any one help!
RE: JR 9xII problem setting model
Your processor has become corrupted by the sounds of it. It needs to go to an authorised service centre for reboot and calibration. Do you see strange symbols in the Model memory lists ?
If you choose model 30, then turn the set off, does it stay on Model 30 or revert back to a different model ?
