If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: 12x vs. 11x
  1. #26
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 12x vs. 11x
    I am thinking of getting an 11x. Does anyone know if a 10x can transfer models to an 11x easily with the transfer cord?
    Vern
  2. #27
    Rafael23cc's Avatar
    Join Date
    May 2002
    Junction City, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 12x vs. 11x
    I am not familiar with the 10x to 11x transfer, but if they work like my 9303 and my 10x then the answer is no. I'll take it a step further, I used to have an analog trim 8103, and later I bought a digital trim 8103. Exact same model but one had digital trims and the other did not. After trying several times, I called Horizon Hobbies and they gave me the news. Since they required different types of memory allocation (digital trim) they were not compatible with the transfer cable.
    A bit of good news is that I have manually copied the numbers from one tx to another and the programming was so close that I only had to adjust it a point or two after flying it several times. I have copied between 7202, 8103, 9303, and 10x, sucessfully. I know it is tedious, but it might be your only choice.
    Rafael
    Keep your eyes on the sky but your feet on the ground!
    Team Heliproz.com / AMA # 8109
  3. #28
    Zeeb's Avatar
    Join Date
    Nov 2004
    Highland Utah UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 12x vs. 11x
    ORIGINAL: vfrank59
    Vern
    Nope..... []
    BUT, Rafael is correct in that you should be able to manually transfer the settings and those should be close. Be sure you double check your actual servo travels before flying though as there will most likely be some changes.
    Zeeb
  4. #29
    RobT's Avatar
    Join Date
    Sep 2003
    Syosset, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 12x vs. 11x
    I moved from a 10x to the 11. I also copied most of the %'s etc and they were very close, but still fine tuning. With that said...it was worth the trouble to upgrade.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
