DX8 Transmitter will not bind
Has anybody seen this issue with their DX8.
On an existing model that has been setup the DX8 will not bind.
If I do a reset model on the Heli it binds fine.
It's as if there is a setting on the transmitter that is stopping the Bind.
When I try on the existing model it says Binding then Bind Failed.
When I try a reset model I get Binding and1024/22ms comes up, then it binds.
This is the same on AR8000, AR7600, AR6110e.
I am also flying a model that has already bound.
RE: DX8 Transmitter will not bind
Just discovered:
Software Bug in 1.02
You have Expo enabled on every single curve. If you change one to INH, it binds. We tested several of them, not all, but the results were consistent.
Thanks for sending the model file.
We'll get this into an update soon.
Andy
Andy
I cannot receive updates, probably because I cannot register. When I put inserial number (13 Characters) It wants 16n more.
Pete
Pete
Pete,
Your serial number starts on the first line with something like HX0008 and continues for 3 more lines. The web guys are working hard to get Version 1.03 out today.
Andy
(Spektrum dev team)
Andy
(Spektrum dev team)
