Can I program a throttle cut switch for my X2720 (X7202) ?
Can one of the switches on my X2720 (X7202)be programmed as a throttle cut?
I know how to program the throttle cut using the throttle trim but wanted a single action switch that was quicker to operate. I have a glow plane that doesn't have an UC so when I come in to land I have to cut the engine before touch down. Obvioiusly I like to do this as quick as I can and close to the strip. Holding the throttle tirm down until it cuts takes a bit of time and while doing this one hand isn't on the controls. I fly Mode 1 so really need both hands, onefor aileron and one forelevator. If I was on mode 2 perhaps not such an issue.
I had a different make of Tx that used a switch for the throttle cut. Can I do the same with my JR or do I need to mix one of my aux switches with the throttle to give 0% throttle when Ioperate the switch?
Greg
