Setting up throttle cut on a DSX9
I’m at a loss here. The DSX9 transmitter has a throttle cut function that is activated by hitting the trainer switch. In the throttle cut menu, you can adjust the travel of the throttle servo by choosing anything between -25% to +25%. Irrespective of whether I choose minus or plus, however, the throttle opens rather than closes when I hit the throttle cut switch. I’ve experienced something similar with other transmitters before, and I have always managed to figure it out in the end, but this one beats me. What am I doing wrong?
