Moving models between 8103s
MN
Danny,
I've currently got an analog trim 8103, and am purchasing a digital trim 8103. Is it possible to move my model memories between the two with a trainer cord, or do I have to re-enter the data manually?
Thanks!
Thanks!
I'm sorry to say that it does have to be done manually. Using the same values should be very close, but there may be some variances that you may have to adjust for. The processors and boards are different in the digital trim system as well as some slight programming differences make the transfer between the two models incompatible.
