JRX9303 2.4 Flap Warning
My Feedback: (10)
When I turn the Tx on, if the flap switch is in the FM1 or FM2 position (I use flight modes) it gives me a warning on the screen and beeps. If the flap switch is in the FM0 position I do not get this warning. I have 2 questions:
1. Can I disable this warning?
2. Is it possible to have this warning on the gear switch instead?
I've researched the manual and cannot find any info on this. Perhaps someone can chime in here and assisit.
Bob
Bob
RE: JRX9303 2.4 Flap Warning
Thats correct. The warning has its roots in the helicopter programming where low stick in FM1 and FM2 is full throttle, a bad bad thing when you light the plug and hit the motor with a starter while you're trying to hang on to the rotor head.
I'll dig out my radio but I'm pretty sure that radio isn't flexable enough to move it or disable it. The 11x has a lot of options where the start up warnings are concerned.
My Feedback: (10)
Andy thanks for your help. Best explanation I've heard so far. My Tx is setup in the accro mode, not helicopter mode, so I wonder why JR has the warning show up in the accro mode? If you find anything more I'd appreciate hearing about. Thanks again for your assistance.
Bob
Bob
