Ultra Stick 60 & JR X-388S
TX
Danny, I have a US60 and am trying to program using the
H9 manual.
Is there a fix similar to the one you published concerning the 8103.
When flaps are assigned to 3 pos switch the laps go full up on the elev position, level on mid and down on the land position.
I can not get them set for the same deflection either.
I have 4721 on ailerons and 517 on flaps.
I thought the flaps were neutral at the ele position, down at mid and crow in land position.
Servos are centered before starting program.
Joel
H9 manual.
Joel
Actually the same modification will work for the 388 as well as the 8103. It can be found here. http://horizon.hobbyshopnow.com/shar...ultrastick.pdf To fix a deflection difference you can adjust each in the travel adjustment funciton possibly combined with some mechanical adjustments.
TX
Danny,
I printed the fix from your site.
I do have some confusion.
Step 2- I do not have a D/Flap T. I have pot.5 Trim.
Step 4- No numbered mixes.
Step 5- No flap to flap mix.
Step 10- Is this Trvl adj?
Would you mind going thru these steps and clarify.
Joel
Joel
Step 2: You will use the function that states pot.5 trim, but hit the channel key to get to pot.6 which is the flap pot. You will activate pot 6 before setting up the mix, then later inhibit it after setting the offset in the mix.
Step 4: In place of the numbers, the 388 uses letters, so in place of mix 3 or 4, you would use mix C or D.
Step 5: The flap to flap mix is a mix you will set up in mix C or D.
Step 10: This is in the program mix that you set up, you will enter the percentage needed to get the flaps level.
If you have any further questions please feel free to give one of our product support techs a call at 877-504-0233.
