JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Programming the DX8 for four wing servos
Reply
Old 11-23-2010, 08:11 PM
ntsmith
Location: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Programming the DX8 for four wing servos
I was thinking of getting the Sebart bipe which has four servos but then began to wonder if there is a useable wing setup in the DX8 and if not will one be added. wht would be the best way of programming the DX8 for these four seperate wing servos? The only wing type shown is for flaps so the nearest is two aileron and two flaps which is NOT what is required.
ntsmith is offline
Old 11-28-2010, 08:31 PM
jschenck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Programming the DX8 for four wing servos
I haven't tried a 4 servo wing yet but I have read it's pretty easy and very capable of running all the mixes for a four servo wing.
Quote:
Enhanced Wing Type ProgrammingWhen selecting a wing type for an airplane, Spektrum AirWare graphically depicts the type you've chosen and will automatically configure the necessary mixes for the pilot. This saves time and reduces the chances for error when programming complex control surface configurations.
http://www.spektrumrc.com/Products/D...ProdID=SPM8800
jschenck is offline
Old 11-28-2010, 09:53 PM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nigel,
I take it you're looking for a 4-aileron setup, correct? I'm not familiar with the airplane you mention. Are you using inner and outer ailerons, or dual servos on two ailerons?
Either way, the 2-Ail/2-Flap configuration will work for you. Leave the Flap System settings at 0, then mix Aileron to RFL (Right Flap). If that doesn't give the right movement, change it to LFL. I have my DX8 packed up right now, but I'll be able to test in the morning when I get to work.
Drop me a PM to remind me, please.
Andy
AndyKunz is offline
Reply
Display Modes
