JR XF622 setup with dual wing servos
My Feedback: (89)
RE: JR XF622 setup with dual wing servos
I do not have a manual however: If you have something in the wing mode..Flaperons..activate it..then use Chan# 2 and Channel #6
If you donot or can not find it...Go to the MIX Channel..Mix Aileron> Chan#6 (Aux#1)..set everything at 100%(may require moving
the Aileron Stick..Hope this helps
Codimasta
AMA 11269
Codimasta
AMA 11269
My Feedback: (13)
You can only activate the flaperon option when setting the wing mode- you need to be in the system menu (holding the two buttons down as the transmitter is turned on) to do this. then yes, channels 2 and 6 will be your left and right ailerons and both can be reversed or travel adjusted seperately.
