10X? Airplane and Heli owner
The 10X is model type specific. You can use the 10X heli to fly aircraft, but some extremely complex programming for aircraft would not be possible. But it will work for most aircraft. The 10X air is aircraft only and can not be used for helis.
Yes, you can set up dual aileron, dual elevator, and aileron differential. Those 3 functions use 4 mixes to set up though, and there are 8 total free mixes in the system. So it is easy to run out of mixes. Yes you would have dual rates on on three, but the 10X air actually has triple rates on all three.
I have not heard of any plans for a new top level TX. I do not think that when there is that it will be for both types. Having it model type specific allows the programming to be fine tuned further for each type.
