MatchBox programming problem
WI
I am setting up a MatchBox and I find that the MatchBox seems to limit the servo travel a bit at the extreme end of servo travel (when the stick is moved full left for instance) even if the Matchbox is PROGRAMMED to give FULL movement. It almost seems that when programming servo #2 for instance and the MatchBox switch is set to program #2, the travel is less than when the Matchbox is set to 0 (no programming), then the travel is a bit more on the servo.
In other words the full travel varies somewhat depending on if you are in program mode (set full end travel for that particular servo) and after programming and MatchBox is in 0 position.
I am using it with the transmitter travel set to 150% (JR 10X) have you a cure for this?
Bill Krueger
Bill Krueger
The travel should not depend on the position of the dial on the matchbox. If the travel changes after programming the servos, perhaps the matchbox is not storing the settings properly. Be sure to not power off the matchbox until you have rotated the dial around to the 0. If the problem still exists, perhaps the matchbox has a problem.
The position of the dial on the matchbox should have no affect on servo travel. Perhaps the matchbox is not storing the settings correctly. Be sure to not power off the matchbox until you have returned the dial to the 0. If the problem still exists, perhaps the matchbox you have has a problem.
