PowerBox Sensor Switch for Spektrum/JR Receivers
My Feedback: (19)
MA
Greetings,
I understand that the Spektrum AR9110 and other similar high end Spektum/JR receivers (not including power box-type systems) that come with dual battery input leads can isolate the 2 batteries in the event one should fail. They also come with a switch that fails open. In light of all that, the only possible advantage of using a PowerBox Sensor Switch instead of the stock switch on these receivers would be voltage regulation. Am I right? Am I missing any another advantage? Also, is there any disadvantage to using these switches on these types of receivers?
Thanks up front.
MT
RE: PowerBox Sensor Switch for Spektrum/JR Receivers
I have question about the JR/Spectrum dual power receivers. I have a new 100cc Yak. I have 7 Hitec servos to install, 6 HS 7954SH, 1 HS 7990TH. I purchased the AR 12110 Spectrum receiver. I was wondering if I can safely fly this set up with dual battery hooked up to the receiver as advertised by JR and Spectrum? Or do I still need some power buss system?
Thanks for the help. My original plan was to install one of the Smartfly systems, but then I saw the JR/Spectrum hign end receivers with dual battery leads. Their ads say they will handle it, I need to know if its true.
My Feedback: (19)
MA
Huh? Why would you post your question here and also repeat it as the start of another thread? Further, it has nothing to do with my inquiry, which pertains to a specific switch...
My Feedback: (41)
ORIGINAL: Beavis
Greetings,
Thanks up front.
Greetings,
Thanks up front.
Does that help?
My Feedback: (19)
MA
Zeeb,
Yes, that helps a lot. Thank you.
As to what I mean by the PowerBox Sensor Switch, please see http://www.powerbox-systems.com/e/po...nsor/start.php . This product is very popular in Europe and I see it quite a bit here in the US as well...
Thanks again,
My Feedback: (41)
ORIGINAL: Beavis
After seeing him use them, I don't like 'em. He's always monkeying around trying to figure out which button to push, how many times and trying to see if the appropriate light is on. That particular switch is useless for an rx pack IMHO since it's limited to 5 amps. The JR/Spektrum rx's which are 9 channel and above including the PowerSafes, can handle 35 amps continous and burst to 50 amps.
