E-Flite Super Cub/AR7010
AZ
I am trying to set up an E-Flite Super Cub using an AR7010 receiver. No problems with channels 1-4. Channel 5 is Gear, and not used.
Channels 6 and 7 are AUX1 and Aux2
I am trying to set up flaps on AUX1, using a a "Y" harness and the three position switch.
Also, trying to set up ailerons independently on channel 2 (AILE) and AUX2. I assume FLAPERON must be "ON".
The results are unsuccessful. Can anyone give me some guidance on how to do this properly?
Thanks in advance,
Frank
Thanks in advance,
Frank
RE: E-Flite Super Cub/AR7010
ORIGINAL: Confuqua
I am trying to set up flaps on AUX1, using a a ''Y'' harness and the three position switch.
Also, trying to set up ailerons independently on channel 2 (AILE) and AUX2. I assume FLAPERON must be ''ON''.
Thanks in advance,
Frank
Thanks in advance,
Frank
