Complex Brake Switch Setup on 9303 2.4
SK, CANADA
I know there are alot of different brake switch setup threads for jets, but can you tell me of the following is even possible?
I use a JR 9303 2.4 with JR 921 Rx, for a R/C Jet application (Boomerang Sprint)....
I would like:
1. a switch for ON/OFF brakes, can be ALWAYS ACTIVE
AND
2. BRAKES mixed to DOWN ELEVATOR that is ALWAYS ON when WHEELS DOWN EXCEPT when WHEELS UP, then NO BRAKES to DOWN ELEV mixing (this mix is INHIBITED)
***NOTE: I currently use only one servo with BEHOTEC retracts on a 3-way valve / 3-way switch for WHEELS UP / WHEELS DOWN / BRAKES
Thanks in advance for your help.
Marc
I would like:
AND
Marc
RE: Complex Brake Switch Setup on 9303 2.4
ORIGINAL: bigbreeze
I would like:
AND
Marc
I would like:
AND
Marc
At one point, I had a Retract valve and a Brake valve from MiniHobbies. These devices had a Solenoid and circuit board wrapped together. I could plug the Brake valve into the Retract valve and it would automatically keep the Brake valve from working when the Retracts were Up. The both started leaking so I sent them back to be repaired. I do not think I used them again. They came with servo leads that plugged directly into the Rx so there was no need to adjust End Points/Travel. The Brake valve was Proportional. I had to switch to the BVM SmartStop II and add a servo, at the Maine Jet Rally, when the failure occured with the Minihobbies Brake Valve.
