mixing problem on JR X-3810
Hi
I am building a turbine powered delta aircraft, and want to use the twin rudders as air brakes when landing.
So how do I programme a mix on two channels that will give me conventional rudders for ground handling (both rudders moving in the same direction) . but air brakes (rudders moving in opposite directions when the mix is activated.
Driving me crazy but bet there is an easy answer.
Do you want the rudder stick to control the air brakes, such as left rudder both rudders deflect out and right both in, or would you like to have both rudders kick in or out on a switch and retain normal rudder control?
Hope you had a good holiday :>)
I would like the rudder control to operate the rudders normally as this will also be used for nosewheel steering.
the landing switch would be used to deflect both rudders out.
I assume that the nosewheel will be connected to the rudder channel, and each of the rudders to two spare channels. But I just can't get the hang of this double mix.
Hope you can help
John
Hope you can help
John
RE: mixing problem on JR X-3810
Ok, well, to set that up it will take 4 program mixes. You would use channel 7 for one side, and channel 8 for the other in the set up I describe below. Start in mix 5, set up a rudder to spoiler mix, and set the rates to +100%. Then in mix 6, set up a rudder to aux 3 mix, and set the rates to +100%.
Then in mix 3, set up an aux 3 to aux 3 mix, press select until the arrow points to offset, rotate the aux 3 pot all the way one way or the other (direction does not matter), and press clear. This should enter in an offset on the screen. Press select until the arrow points at SW: and press the + key until it says LAND. Then press select until the arrow points at Rate, and set the rate as needed for that side.
Then in mix 4, set up an spoi to spoi mix, press select until the arrow points to offset, rotate the spoiler pot all the way one way or the other (direction does not matter), and press clear. This should enter in an offset on the screen. Press select until the arrow points at SW: and press the + key until it says LAND. Then press select until the arrow points at Rate, and set the rate as needed for that side.
In both cases, if the direction of the movement is backwards, switch from + percentages to - percentages. I hope this helps!
It works :>)
Thanks Danny, I am glad it wasn't too easy, saves me having to kick myself.
Thanks again John
Thanks again John
