AR9000 blinking light
I have an AR9000 receiver that has one blinking light on it. After turning it on the satellite receiver light is on and the light near one end of the AR9000 is on. The light near one of the satellite receiver ports is blinking. Does anybody have a clue as to why? I've not done a range test but everything seems to work normally.
Thanks!
Ken
Thanks!
Ken
RE: AR9000 blinking light
ORIGINAL: kenh3497
Thanks!
Ken
Thanks!
Ken
ORIGINAL: BuschBarber
I have several AR9000 Rx's. One time, I made a change to an aircraft, at a private airport where I fly sometimes. I had to Bind again. I was next to a large metal aircraft hangar. Every time I tried to Bind, one light in the Main Rx would stay Blinking. I called Horizon and they said it was because of the metal hangar. I moved out into the field and I was able to Bind without issue.
ORIGINAL: kenh3497
Thanks!
Ken
Thanks!
Ken
OK, I'll give that a try. I was in my basement surrounded by concrete and wood and that receiver has been bound without issues until now. Thanks!! Oh for the days of turning everything on and it just "works" with out issue. (72 Mgh equipment).
Ken
Well, the AR9000 fixed it's self. Maybe I had the TX to close and it swamped the RX?????? In any case I was going to rebind tonight and do a little other setup and low and behold no blinking lights. I didn't do anything except turn it on. The TX was about 3 feet away this time.
Ken
Ken
